Kensington Locking Kit Surface Studio
Quicklinx: G8C6WS00 Mfr#: K67976WW
£42.16 ex VAT
£50.59 inc VAT
From the industry leader with 25 years of expertise in physical device security, Kensington has created the exclusive option to lock down Surface Studio to guard against and deter theft. Engineered specifically for the groundbreaking device, the kit consists of a lock adapter and the MiniSaver Keyed Lock that work together to keep the Surface Studio safe. As an official participant in Microsoft's Designed for Surface program, Kensington worked closely with their engineers to ensure we created the strongest possible security solution. Cleat Locking Technology connects the lock to the adapter and a carbon steel cable anchors to a fixed object so the Surface Studio stays where it's supposed to stay.
  • Surface Studio lock adapter
    Built for strength and designed specifically to provide security for the groundbreaking device to thwart theft.
  • MiniSaver keyed lock
    Featuring Cleat locking technology, the retracting claws grab on to the internal sides of the lock adapter, creating a strong connection to help ensure your Surface Studio stays where it belongs.
  • Carbon steel cable
    Offering the same level of cut-resistance and theft-resistance as thicker cables, the carbon steel cable with plastic sheath offers security and greater flexibility.
  • Push-button design
    Allows for one-handed engagement into the lock adapter, quickly and easily attaching the lock inside the Kensington mini security slot.
  • Pivot and rotate cable
    Special hinge creates great freedom of movement, eliminating awkward angles and allowing you to insert your key with complete ease.
Kensington Locking Kit - security cable lock set
Security cable lock set
Package Content
Security cable, 2 x keys, lock slot adapter, lock
Black, silver
Product Material
Carbon steel
Length
1.8 m
Pivot adjustment, rotating, Cleat Locking Technology, cut-resistant, standard keyed
5-year warranty
Product Material
Carbon steel
Package Content
Length
1.8 m
Diameter
4.5 mm
Black, silver
Security Cable Lock
Lock Method
Key
Limited warranty: - 5 years
Brand: Kensington
