Kensington Locking Kit Surface Studio - Single Keyed
Quicklinx: G8C2WS00 Mfr#: K67970S
£42.16 ex VAT
£50.59 inc VAT
From the industry leader with 25 years of expertise in physical device security, Kensington worked with Microsoft's engineers to create a seamless locking solution for the groundbreaking Surface Studio to guard against theft. The kit consists of a lock adapter and the MiniSaver Keyed Lock that work together to keep the Surface Studio safe. As an official participant in Microsoft's Designed for Surface program, Kensington worked closely with the Surface team to ensure we created the strongest possible security solution. Cleat Locking Technology connects the lock to the adapter and a carbon steel cable anchors to a fixed object so the Surface Studio stays where it's supposed to stay.
  • Lock adapter
    Built for strength and designed specifically to provide security for your device to thwart theft.
  • Keyed lock
    Featuring Cleat locking technology, the retracting claws grab on to the internal sides of the lock adapter, creating a strong connection to help ensure your device stays where it belongs.
  • Pivot and rotate cable
    Special hinge creates great freedom of movement, eliminating awkward angles and allowing you to insert your key with complete ease.
Kensington Locking Kit - Supervisor Keyed - security cable lock set
Security cable lock set
Package Content
Security cable, 2 x keys, lock slot adapter, lock
Product Material
Steel, carbon
Pivot adjustment, rotating, Cleat Locking Technology, cut-resistant, supervisor keyed
Product Material
Steel, carbon
Package Content
