Kensington KGuard Monitor Mounted Desk Screen
Quicklinx: G8TFWS00 Mfr#: 627506
£67.56 ex VAT
£81.07 inc VAT
Increase protection without creating barriers with the Kensington KGuard Monitor Mounted Desk Screen. KGuard is a clear acrylic sneeze guard fitted behind an arm-mounted monitor, requiring minimal fitting. The desk screen moves with the monitor unlike traditional office desk partitions and furniture and takes up no desk space. Three height adjustment settings to accommodate different sized monitors and provide optimal protection. KGuard surface can be used with dry wipe markers for note taking, reminders, as a whiteboard, etc. Cut-outs provide effective access for monitor cables whilst not compromising protection. Acrylic screen is 100% recyclable. Compatible with VESA 75/100 monitors up to 32".
  • Clear acrylic sneeze guard
    Fits behind an existing monitor and monitor mount/arm to enhance Coronavirus protection and social distancing.
  • Zero footprint
    Takes up no desk space and moves with the monitor arm.
  • Height-adjustable
    Three settings accommodate different sized monitors and provide optimal protection.
  • Additional uses
  • Cable cutouts
    Provide effective access for monitor cables whilst not reducing protection.
  • Screen 100% recyclable
    Non-toxic, pure material that is easy to reuse or recycle.
Kensington KGuard - partition screen - monitor mountable - 120 x 74 cm - clear
Partition screen - monitor mountable
Size
120 x 74 cm
Adjustable Height
Clear
Material
Acrylic
Size
120 x 74 cm
Adjustable Height
Clear
Material
Acrylic
Non-toxic, cable cut out
1200 mm
3 mm
740 mm
Recyclable
Brand: Kensington
