Providing the trusted protection that has made Kensington The Professionals' Choice in laptop security for over 25 years, Kensington's Keyed Cable Lock sets the standard for securing Surface Pro and Surface Go. Providing vigorously tested, non-invasive locking technology that is supported by Kensington's innovative common keying system, the Keyed Cable Lock is the superior security solution for Surface Pro and Surface Go.
 - Kensington Keyed Cable Lock for Surface Pro - Supervisor Keyed - security cable lock
- Product Type
 - Security cable lock
- Product Material
 - Carbon steel
 - Hidden pin
- Designed For
 - Microsoft Surface Go, Go 2, Pro (Mid 2017), Pro 4, Pro 6, Pro 7
- Product Type
- Product Material
 - Carbon steel
 - Hidden pin
- Designed For
