Kensington Keyed Cable Lock For Surface Pro
Quicklinx: DPT1WS00 Mfr#: K62044WW
Providing the trusted protection that has made Kensington The Professionals' Choice in laptop security for over 25 years, Kensington's Keyed Cable Lock sets the standard for securing Surface Pro. Providing vigorously tested, non-invasive locking technology that is supported by Kensington's innovative common keying system, the Keyed Cable Lock is the superior security solution for Surface Pro.
  • Enhanced security
    The Kensington Keyed Cable Lock for Surface Pro & Surface Go offers a robust solution to keep your device secure. Featuring a hidden pin mechanism, this lock provides an extra layer of protection against tampering.
  • Durable design
    Crafted from carbon steel, the security cable lock is designed to withstand attempts to cut or break it, ensuring your tablet remains safe in public spaces or high-traffic environments.
Kensington Keyed Cable Lock for Surface Pro & Surface Go - security cable lock
Security cable lock
Product Material
Carbon steel
Length
1.8 m
270 g
Hidden pin
5-year warranty
Microsoft Surface Go, Go 2, Pro (Mid 2017), Pro 4, Pro 6, Pro 7
Security cable lock
Product Material
Carbon steel
Length
1.8 m
Thickness
5 mm
270 g
Security Cable Lock
Intended For
Tablet
Lock Method
Key
Hidden pin
Limited warranty: - 5 years
