Kensington Kensington Pro Fit® Wireless Mobile Mouse - Black
Quicklinx: C1GTWS00 Mfr#: K72452WW
Recommended Use: Leisure
Type: Mouse
Wired / Wireless: Wireless
Colour: Black
Compatibility: Mac, PC
25 In Stock
£19.66 ex VAT
£23.59 inc VAT
When you need a compact, mobile mouse that offers wireless performance and comfort, the Kensington Pro Fit Wireless Mouse has everything you need to be productive. The 2.4GHz connection means there are no wires to worry about and the high definition 1000 DPI laser sensor lets you scroll around your screen with precision control. The two-button, scroll wheel design is highly intuitive and works equally well for both right-handed and left-handed users. And best of all, with simple and easy Plug & Play installation, youll be up and ready in no time after you plug in the nano receiver.
  • Wireless connection
    Allows for complete freedom and mobility.
  • High-definition tracking
    1000 dpi laser sensor for enhanced performance.
  • Convenient design
    The comfortable two-button, scroll-wheel design is suitable for both right- and left-handed users.
Kensington Pro Fit Mobile - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
Orientation
Right and left-handed
9.64 cm x 5.8 cm x 3.3 cm
80 g
Worldwide
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
Buttons Qty
2
Movement Resolution
1200 dpi
Scrolling wheel, Nano wireless receiver, ambidextrous design, automatic power off
AA type
Apple MacOS, Microsoft Windows Vista / XP / 7 / 8 / 8.1
3-year warranty
Mouse
Wireless Receiver
Orientation
9.64 cm
5.8 cm
3.3 cm
80 g
Worldwide
Input Device
Wireless
2.4 GHz
Laser
Buttons Qty
2
Movement Resolution
1200 dpi
1 x USB - 4 pin USB Type A
Plug and Play
AA type
Limited warranty - 3 years
Type: Mouse
Colour: Black
Compatibility: Mac
Compatibility: PC
Brand: Kensington
