The ideal companion when youre heading abroad and need to charge the battery on your devices, the International Travel Adapter provides professional-level, simultaneous charging of up to three devices in over 150 countries. Dual USB ports make it easy to charge smartphones and tablets, including the iPhone, iPad, Galaxy S, Microsoft Surface, or other favorite devices. Plus, with the 2-pole adapter you can power anything from a laptop to a 2-in-1 hybrid like the Surface Pro.
                Plugs for US/Japan, AUS/China, UK, EUSimply push the integrated plug release button to one the four sliders on the side of the adapter to slide out the correct plug configuration for the wall outlet of the country you are visiting. When you're done charging, just slide it back into the adapter.
                2-Pole adapterAllows you to power higher-draw devices like a laptop.
                Dual 2.4A USB portsThe ports allow you to get the fastest charge possible for one tablet or two smartphones.
                Compact designMakes it very easy to pack, and since the all the prongs retract back into the main housing when charging is completed, there's no chance of leaving loose pieces behind.
                Internal fuseProvides complete peace of mind, protecting your devices and their internal components from getting damaged due to a power surge.
- Kensington International Travel Adapter power adapter - BS 1363, NEMA 1-15, Europlug, AS/NZS 3112, 2 x USB
- Product Type
- Power adapter
- Designed For
- Portable player, tablet, mobile phone
- 5 cm x 5 cm x 6 cm
- Black
- Localisation
- Australia, China, Japan, United Kingdom, United States, Europe
- Output Connector Type
- Power Device Details
- 2 x - 4 pin USB Type A - 2.4 A
- 2-year warranty
- Product Type
- Power adapter
- Designed For
- 5 cm
- 5 cm
- 6 cm
- Enclosure Colour
- Black
- Localisation
- Input Connectors
- Power BS 1363, power NEMA 1-15, Europlug (power CEE 7/16), power AS/NZS 3112
- Output connectors
- Power BS 1363, power NEMA 1-15, Europlug (power CEE 7/16), power AS/NZS 3112, 2 x 4 pin USB Type A
- 2 x 4 pin USB Type A - 2.4 A
- Limited warranty - 2 years
