Kensington Expert Mouse Optical
Customer rating: 5.0* (Write a review)
Quicklinx: 39Y6WS00 Mfr#: 64325
Recommended Use: Mobile
Type: Trackball
Wired / Wireless: Wired
Colour: Black
Compatibility: PC
£93.06 ex VAT
£111.67 inc VAT
The Expert Mouse Wired Trackball is the ultimate productivity enhancer that makes working at the desk quicker, more accurate and extremely comfortable for your hand and wrist. Featuring DiamondEye technology, the trackball uses optical tracking to precisely follow small flecks embedded in the large 55mm ball to provide smooth, accurate cursor control. The four buttons are customizable using our highly intuitive TrackballWorks software, while our award-winning Scroll Ring lets you quickly scan up and down web pages and large documents. Add it all up and you get exceptional comfort and ease-of-use that has set the industry standard for more than 20 years.
Kensington Expert Mouse - trackball - USB - black
Trackball
Wired - USB
Orientation
Right and left-handed
Movement Detection Technology
Optical
Buttons Qty
4
DiamondEye technology, removable wrist rest
Microsoft Windows 7 or later, Apple MacOS X 10.8 or later, Google Chrome OS 44 or later
Microsoft Certification
Compatible with Windows 7
3-year warranty
Trackball
Orientation
Input Device
Wired
USB
Optical
Buttons Qty
4
1 x USB - 4 pin USB Type A
Wrist rest
FCC
Software Included
Drivers & Utilities
Limited warranty - 3 years
Resources
The following resources are available for the Kensington Expert Mouse Optical
Customer reviews
Write a review for the Kensington Expert Mouse Optical here!
Expert mouse
Reviewed by George. Review Posted 29/11/2005
Expensive-so very expensive-BUT-so good, so very good. If you use a trackball, then this is one of the best, easy to configure, big ball makes for precise movements, keys are big enough to hit easily. Gave it a 4 for ease of use till you get used to having your wrist on the pad, and 4 for value-well it is expensive.
  • Overall 5*
  • Ease of use 4*
  • Value for money 4*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Type: Trackball
Colour: Black
Compatibility: PC
Brand: Kensington
