Kensington Easy Riser Go Laptop Cooling Stand - Notebook sta
Quicklinx: G62HWS00 Mfr#: K50421EU
Device Type: Laptop, Notebook
Type: Laptop Stand
Device Screen Size: 14
Colour: Silver
£14.15 ex VAT
£16.98 inc VAT
Combine the ergonomic benefits of raising your screen height with the technological benefits of increased air circulation for your laptop or tablet with the Kensington SmartFit Easy Riser Go Adjustable Ergonomic Laptop/Tablet Riser and
Cooling Stand. The sleek 2-in-1 design is height and angle adjustable to improve posture, promote proper eye alignment and support neck and shoulder comfort while keeping the laptop or tablet's internal components cool. Anti-slip foot pads prevent the stand from sliding forward, padded inserts provide a secure fit for your device, and the slim foldable design is made for travel. Use with an external keyboard and mouse (sold separately). Supports laptops and tablets up to 14".
  • SmartFit system
    Allows you to dial in your ideal height setting using the color-coded fitting chart, with up to a 50-degree tilt angle so you can make a fast adjustment in two easy steps.
  • Secure fit
    Padded inserts provide non-slip stability for any laptop, keeping it firmly and safely in place while you work.
  • Increased air circulation
    By lifting laptop off the desktop, it dissipates heat buildup and keeps the laptop cooler, easing the strain on the battery and internal components.
  • Highly portable
    Designed to quickly and easily fold flat so it saves space in your bag when you're traveling on long or short trips.
Kensington Easy Riser Go Laptop Cooling Stand - notebook stand
Notebook stand
Notebook Compatibility
14"
SmartFit, anti-slip feet, adjustable angle (8 positions)
Notebook stand
14"
Device Type: Laptop
Device Type: Notebook
Type: Laptop Stand
Colour: Silver
Brand: Kensington
