Kensington Easel Copyholder
Quicklinx: 56CWWS00 Mfr#: 62405
Type: Copy Holder
10 In Stock
£10.54 ex VAT
£12.64 inc VAT
The InSight Plus Easel Copyholder is designed to hold documents comfortably to reduce neck and eyestrain as you read or type. Four angle settings mean it can be easily adjusted for optimum use while it is flexible to hold up to 50 A4 sheets. Its magnified line guide also helps keep your eyes on track and it is fully collapsible for compact storage.
Kensington InSight Plus Easel Copyholder - copy holder
Copy holder
Grey
443 g
Magnetic fixing
Copy holder
443 g
Grey
Magnetic fixing
Limited warranty: - 2 years
Type: Copy Holder
Brand: Kensington
