Kensington Duo Gel Mouse Wrist Rest - Smoke
Quicklinx: 8XYGWS00 Mfr#: 62399
Accessory Type: [N/A]
10 In Stock
£16.95 ex VAT
£20.34 inc VAT
The Duo Gel Mouse Pad combines a durable vinyl pad, providing a rigid base for fast and accurate mouse movement, with a wrist rest that moulds itself to your wrist shape for complete comfort and support. Available in a choice of 3 stylish duo-tone colours, it features a ventilation channel to keep hands cool and dry and has an easy wipe-clean finish.
  • Mouse pad features dedicated wrist rest
  • Gel pillow matches natural curve of wrist and hand for comfortable computing
  • Ventilation channel helps keep hands cool and dry
  • Gel pillow
    The soft structure molds to the natural curvature of your wrist, providing support and comfort while you work for a better typing experience.
    Strategically designed to help keep your hands and wrists cooler and drier when scrolling and clicking for extended periods of time.
  • Duo-tone colors
    Stylish accents to give your wrist rest a little extra personal flavor on the desktop.
  • Soft finish
    Makes it easy to wipe clean when it inevitably gets dirty from long hours navigating on your computer.
Kensington Duo Gel Mouse Wristrest Wave mouse pad with wrist pillow
Mouse pad with wrist pillow
182 mm x 25 mm x 240 mm
730 g
Two-tone graphite
182 mm
25 mm
240 mm
730 g
Two-tone graphite
Gel filled
Brand: Kensington
