The Kensington Duo Gel Mouse Pad with Wrist Support is a soft structure that moulds to the natural curvature of your wrists, providing support and comfort while you work for a better typing experience. Strategically designed with a ventilation channel to help keep your hands and wrists cooler and drier scrolling and clicking for extended periods of time. With a soft finish that is easy to wipe clean when it inevitably gets dirty from long hours navigating on your computer. The rest meets MIL-STD-810H Method 504.3 Contamination by Fluids testing for resistance to breakdown when exposed to cleaning and disinfecting solvents such as alcohol and bleach for at least 24 hours.
- Kensington Duo Gel Mouse Pad Wrist Rest - mouse pad with wrist pillow - TAA Compliant
- Product Type
- Mouse pad with wrist pillow
- Product Material
- Gel, vinyl
- 18.2 cm x 24 cm x 2.5 cm
- 420 g
- Black, red
- TAA Compliant
- 1-year warranty
- Product Type
- Product Material
- Gel, vinyl
- 18.2 cm
- 24 cm
- 2.5 cm
- 420 g
- Black, red
- Rigid base, ventilation channel
- TAA Compliant
- Limited warranty - 1 year
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
8XYF 050633 Condition: Customer return - item has been opened but is in excellent condition |
£11.00 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
