Kensington Duo Gel Mouse Wrist Rest - Red / Black
Quicklinx: 8XYFWS00 Mfr#: 62402
Accessory Type: [N/A]
£16.04 ex VAT
£19.24 inc VAT
The Kensington Duo Gel Mouse Pad with Wrist Support is a soft structure that moulds to the natural curvature of your wrists, providing support and comfort while you work for a better typing experience. Strategically designed with a ventilation channel to help keep your hands and wrists cooler and drier scrolling and clicking for extended periods of time. With a soft finish that is easy to wipe clean when it inevitably gets dirty from long hours navigating on your computer. The rest meets MIL-STD-810H Method 504.3 Contamination by Fluids testing for resistance to breakdown when exposed to cleaning and disinfecting solvents such as alcohol and bleach for at least 24 hours.
Kensington Duo Gel Mouse Pad Wrist Rest - mouse pad with wrist pillow - TAA Compliant
Mouse pad with wrist pillow
Product Material
Gel, vinyl
18.2 cm x 24 cm x 2.5 cm
420 g
Black, red
TAA Compliant
1-year warranty
Product Material
Gel, vinyl
18.2 cm
24 cm
2.5 cm
420 g
Black, red
Rigid base, ventilation channel
TAA Compliant
Limited warranty - 1 year
Brand: Kensington
