The Duo Gel Mouse Pad combines a durable vinyl pad, providing a rigid base for fast and accurate mouse movement, with a wrist rest that moulds itself to your wrist shape for complete comfort and support. Available in a choice of 3 stylish duo-tone colours, it features a ventilation channel to keep hands cool and dry and has an easy wipe-clean finish.
- Mouse pad features dedicated wrist rest
- Gel pillow matches natural curve of wrist and hand for comfortable computing
- Ventilation channel helps keep hands cool and dry
Gel pillow
The soft structure molds to the natural curvature of your wrist, providing support and comfort while you work for a better typing experience. -
Ventilation channel
Strategically designed to help keep your hands and wrists cooler and drier when scrolling and clicking for extended periods of time. -
Duo-tone colors
Stylish accents to give your wrist rest a little extra personal flavor on the desktop. -
Soft finish
Makes it easy to wipe clean when it inevitably gets dirty from long hours navigating on your computer.
- Kensington Duo Gel Mouse Pad Wrist Rest - mouse pad with wrist pillow - TAA Compliant
- Product Type
- Mouse pad with wrist pillow
- Product Material
- Gel, vinyl
- 18.2 cm x 24 cm x 2.5 cm
- 420 g
- Black, blue
- TAA Compliant
- 1-year warranty
- Product Type
- Product Material
- Gel, vinyl
- 18.2 cm
- 24 cm
- 2.5 cm
- 420 g
- Black, blue
- Rigid base, ventilation channel
- TAA Compliant
- Limited warranty - 1 year
