Kensington Duo Gel Mouse Wrist Rest - Black / Purple
Quicklinx: 76BJWS00 Mfr#: 62401
14 In Stock
£16.98 ex VAT
£20.37 inc VAT
The Duo Gel Mouse Pad combines a durable vinyl pad, providing a rigid base for fast and accurate mouse movement, with a wrist rest that moulds itself to your wrist shape for complete comfort and support. Available in a choice of 3 stylish duo-tone colours, it features a ventilation channel to keep hands cool and dry and has an easy wipe-clean finish.
  • Mouse pad features dedicated wrist rest
  • Gel pillow matches natural curve of wrist and hand for comfortable computing
  • Ventilation channel helps keep hands cool and dry
  • Gel pillow
    The soft structure molds to the natural curvature of your wrist, providing support and comfort while you work for a better typing experience.
    Strategically designed to help keep your hands and wrists cooler and drier when scrolling and clicking for extended periods of time.
  • Duo-tone colors
    Stylish accents to give your wrist rest a little extra personal flavor on the desktop.
  • Soft finish
    Makes it easy to wipe clean when it inevitably gets dirty from long hours navigating on your computer.
Kensington Duo Gel Mouse Pad Wrist Rest - mouse pad with wrist pillow - TAA Compliant
Mouse pad with wrist pillow
Product Material
Gel, vinyl
18.2 cm x 24 cm x 2.5 cm
420 g
Black, blue
TAA Compliant
1-year warranty
Product Material
Gel, vinyl
18.2 cm
24 cm
2.5 cm
420 g
Black, blue
Rigid base, ventilation channel
TAA Compliant
Limited warranty - 1 year
Brand: Kensington
