Product
Kensington CV4000H USB C 4K HDMI Adapter
Quicklinx: CRJ6WS00 Mfr#: K33993WW
£19.40 ex VAT
£23.28 inc VAT
A professional-level video adapter that allows you to extend your display to 4K Ultra HD from your USB-C port. The adapter is ideal for desktop productivity expansion, or connecting to the video equipment in a conference room for a presentation. The adapter offers extend mode or mirror mode and is also compatible with Thunderbolt 3 ports.
  • 4K Ultra HD
    This adapter gives you video expansion to a monitor, TV or projector via the crystal-clear resolution of 4K Ultra HD. It's also backward compatible with 1080p Full HD so you can just as easily connect to legacy monitors.
  • Extend or mirror modes
    Extend mode allows you to drag an open application to an external monitor so you can work across multiple screens, while mirror mode allows you to replicate the content that's on your computer display to an external screen.
  • Plug-and-Play
    Simply plug in the adapter and it will run automatically without the need for drivers or software downloads.
  • High-quality construction
    Using high-quality components means that you'll know your adapter will perform when you need it to and is completely safe to use with your USB-C laptop, 4K monitor, TV or projector.
Kensington CV4000H USB-C 4K HDMI Adapter - external video adapter
External video adapter
Bus Type
USB-C
Max Resolution
1920 x 1200
HDMI
2 years warranty
Bus Type
USB-C
Max Resolution
1920 x 1200
HDMI
HD/4k Ready, Thunderbolt 3 compatible
Google Chrome OS, Apple MacOS X 10.10, Apple MacOS X 10.11, Windows 8.1 / 10
Plug and Play
Brand: Kensington
Price Range Ex VAT: 0 - 50
