Kensington Combination Lock for Surface Pro and Surface Go
Quicklinx: G8PNWS00 Mfr#: K66301EU
Designed in collaboration with Microsoft , the Combination Lock for Surface Pro and Surface Go delivers uncompromised security. Non-invasive locking technology is supported by a secure carbon steel cable. From Kensington, inventor and worldwide leader in laptop security locks.
  • Exclusively designed for Surface
    Kensington worked directly with Microsoft to provide professional-level security and superior device engagement, so you can secure your Surface Pro or Surface Go with confidence.
  • Non-invasive locking technology
    An easy-to-use security solution that requires no device modifications, preserving the Surface Pro's hardware warranty and aesthetics.
  • Strong lock head
    Tested for torque/pull, foreign implements, lock lifecycle, corrosion, strength, and other environmental conditions, this lock head meets Kensington's industry-leading standards for tamper resistance, reliability, and durability.
  • Carbon steel cable
    Six foot (1.8m) plastic sheath-covered cable resists tampering and offers the same level of cut-resistance and theft-deterrence as thicker cables.
  • Register & Retrieve
    Free quick, secure online code registration program.
Kensington Combination Lock - security cable lock
Security cable lock
Product Material
Carbon steel
Length
1.8 m
190 g
Tamper-proof, anti-theft protection, cut-resistant, non-invasive
Europe
Microsoft Surface Go, Pro (Mid 2017)
Security cable lock
Product Material
Carbon steel
Length
1.8 m
Diameter
4.3 mm
190 g
Europe
Security Cable Lock
Intended For
Tablet
Lock Method
Combination
Limited warranty: - 2 years
