The ClickSafe Universal Combination Laptop Lock – Master Coded fits any laptop security slot – standard T-bar, nano or wedge-shaped – to lock down your laptop, regardless of brand or generation. The master-coded solution makes lock management a breeze. From Kensington, inventor and worldwide leader in laptop security locks.
Enhanced security
The Kensington ClickSafe Universal Combination Laptop Lock - Master Coded features a T-bar lock mechanism, providing a secure anchor to prevent theft and unauthorized use of your device. -
Robust build
Crafted from carbon steel, this security cable lock is cut-resistant, offering superior strength and durability to keep your laptop safe. -
User-friendly design
With its combination lock feature, this lock allows for a keyless convenience while ensuring your device remains protected against theft.
- Kensington ClickSafe Universal Combination Laptop Lock - Master Coded - security cable lock
- Product Type
- Security cable lock
- Product Material
- Carbon steel
- Length
- 1.8 m
- Combination lock, T- bar lock, cut-resistant
- Localisation
- Europe
- 2-year warranty
- Product Type
- Product Material
- Carbon steel
- Length
- 1.8 m
- Localisation
- Europe
- Limited warranty: - 2 years
