From the industry leader in physical device security for 25 years, Kensington's ClickSafe 2.0 Keyed Laptop Lock offers all the strength and one-click convenience and keyless engagement of the original, but in a smaller, uncompromised design. Featuring the 5mm keying system with anti-pick Hidden Pin Technology, the ClickSafe lock head snaps onto the ClickSafe Security Anchor after it has been installed into the Kensington Security Slot found in most laptops. A carbon steel cable deters cutting attempts and the pivot & rotate hinge prevents awkward angles when inserting the key.
Smaller, uncompromised lock head
Designed to fit sleeker laptops, POS systems and a wide variety of other devices, the fully rotating head provides all the strength and anti-theft features you'd come to expect from the industry leader in physical device. -
5mm keying system
A central pillar of Kensington's industry-leading locking solutions, the exclusive keying system is common across all of Kensington's latest locks. The unparalleled custom management options provide flexibility, and patented anti-pick Hidden Pin Technology offer complete peace of mind. Now IT directors will only have one keying system to manage across their organization. -
ClickSafe locking technology
After the ClickSafe Security Anchor featuring a T-Bar has been securely mounted inside the industry-standard Kensington Security Slot on your device, the ClickSafe lock head can be attached in a single click with one hand, providing an unparalleled combination of security and convenience for higher employee compliance. -
Carbon steel cable
Offering the same level of cut-resistance and theft-resistance as thicker cables, the carbon steel cable with plastic sheath offers security and greater mobility with 1.8m (6 ft.) of cable. -
Pivot and rotate cable
Special hinge creates great freedom of movement, eliminating awkward angles and allowing you to insert your key with complete ease. -
Register & Retrieve
Kensington's online key registration program that allows for quick, secure and easy key replacement if it ever gets lost or stolen.
- Kensington ClickSafe 2.0 Keyed Laptop Lock - Supervisor Keyed - security cable lock
- Product Type
- Security cable lock
- Product Material
- Carbon steel
- Length
- 1.8 m
- Corrosion protection, pivot adjustment, master keyed, ClickSafe locking mechanism, ClickSafe Security Anchor, cut-resistant, hidden pin, rotatable, supervisor keyed, 5mm Keying System
- Limited lifetime warranty
- Product Type
- Product Material
- Carbon steel
- Length
- 1.8 m
- Limited warranty: - lifetime
