From the industry leader in physical device security for 25 years, Kensington's ClickSafe 2.0 Keyed Laptop Lock offers all the strength and one-click convenience and keyless engagement of the original, but in a smaller, uncompromised design. Featuring the 5mm keying system with anti-pick Hidden Pin Technology, the ClickSafe lock head snaps onto the ClickSafe Security Anchor after it has been installed into the Kensington Security Slot found in most laptops. A carbon steel cable deters cutting attempts and the pivot & rotate hinge prevents awkward angles when inserting the key.
                Smaller, uncompromised lock headDesigned to fit sleeker laptops, POS systems and a wide variety of other devices, the fully rotating head provides all the strength and anti-theft features you'd come to expect from the industry leader in physical device.
                5mm keying systemA central pillar of Kensington's industry-leading locking solutions, the exclusive keying system is common across all of Kensington's latest locks. The unparalleled custom management options provide flexibility, and patented anti-pick Hidden Pin Technology offer complete peace of mind. Now IT directors will only have one keying system to manage across their organization.
                ClickSafe locking technologyAfter the ClickSafe Security Anchor featuring a T-Bar has been securely mounted inside the industry-standard Kensington Security Slot on your device, the ClickSafe lock head can be attached in a single click with one hand, providing an unparalleled combination of security and convenience for higher employee compliance.
                Carbon steel cableOffering the same level of cut-resistance and theft-resistance as thicker cables, the carbon steel cable with plastic sheath offers security and greater mobility with 1.8m (6 ft.) of cable.
                Pivot and rotate cableSpecial hinge creates great freedom of movement, eliminating awkward angles and allowing you to insert your key with complete ease.
                Register & RetrieveKensington's online key registration program that allows for quick, secure and easy key replacement if it ever gets lost or stolen.
- Kensington ClickSafe 2.0 Keyed Laptop Lock - Supervisor Keyed - security cable lock
- Product Type
- Security cable lock
- Product Material
- Carbon steel
- Length
- 1.8 m
- Corrosion protection, pivot adjustment, master keyed, ClickSafe locking mechanism, ClickSafe Security Anchor, cut-resistant, hidden pin, rotatable, supervisor keyed, 5mm Keying System
- Limited lifetime warranty
- Product Type
- Product Material
- Carbon steel
- Length
- 1.8 m
- Limited warranty: - lifetime
