Kensington ClickSafe 2.0 Lock - Master Keyed
Quicklinx: G8BDWS00 Mfr#: K64436M
From the industry leader in physical device security for 25 years, Kensington's ClickSafe 2.0 Keyed Laptop Lock offers all the strength and one-click convenience and keyless engagement of the original, but in a smaller, uncompromised design. Featuring the 5mm keying system with anti-pick Hidden Pin Technology, the ClickSafe lock head snaps onto the ClickSafe Security Anchor after it has been installed into the Kensington Security Slot found in most laptops. A carbon steel cable deters cutting attempts and the pivot & rotate hinge prevents awkward angles when inserting the key.
  • Smaller, uncompromised lock head
    Designed to fit sleeker laptops, POS systems and a wide variety of other devices, the fully rotating head provides all the strength and anti-theft features you'd come to expect from the industry leader in physical device.
  • 5mm keying system
    A central pillar of Kensington's industry-leading locking solutions, the exclusive keying system is common across all of Kensington's latest locks. The unparalleled custom management options provide flexibility, and patented anti-pick Hidden Pin Technology offer complete peace of mind. Now IT directors will only have one keying system to manage across their organization.
  • ClickSafe locking technology
    After the ClickSafe Security Anchor featuring a T-Bar has been securely mounted inside the industry-standard Kensington Security Slot on your device, the ClickSafe lock head can be attached in a single click with one hand, providing an unparalleled combination of security and convenience for higher employee compliance.
  • Carbon steel cable
    Offering the same level of cut-resistance and theft-resistance as thicker cables, the carbon steel cable with plastic sheath offers security and greater mobility with 1.8m (6 ft.) of cable.
  • Pivot and rotate cable
    Special hinge creates great freedom of movement, eliminating awkward angles and allowing you to insert your key with complete ease.
  • Register & Retrieve
    Kensington's online key registration program that allows for quick, secure and easy key replacement if it ever gets lost or stolen.
Kensington ClickSafe 2.0 Keyed Laptop Lock - Master Keyed - security cable lock
Security cable lock
Product Material
Carbon steel
Length
1.8 m
Corrosion protection, pivot adjustment, master keyed, ClickSafe locking mechanism, ClickSafe Security Anchor, cut-resistant, hidden pin, rotatable, 5mm Keying System
Security cable lock
Product Material
Carbon steel
Length
1.8 m
Limited warranty: - lifetime
