Lock head provides trusted protection that only Kensington can provide. The lock head fits slim devices securely while allowing them to remain in complete contact with flat surfaces.
Flexible compatibility
Offers flexible compatibility with select Kensington keying systems, so you can leverage Kensington custom keying solutions across your organization. -
Pivot & rotate cable
Fully rotating cable creates greater freedom of movement, eliminating awkward angles and allowing you to insert your key with complete ease.
- Kensington ClickSafe 2.0 Keyed Laptop Lock - Standard Keyed - for Dell Devices - security cable lock
- Product Type
- Security cable lock
- Product Material
- Carbon steel
- Pivot adjustment, ClickSafe Security Anchor, cut-resistant, hidden pin, rotatable, Tough Lock Head lock
- Localisation
- Europe
- Product Type
- Product Material
- Carbon steel
- Localisation
- Europe
