Kensington ClickSafe 2.0 Keyed Laptop Lock for Dell Devices
Quicklinx: G8BSWS00 Mfr#: K66638EU
Lock head provides trusted protection that only Kensington can provide. The lock head fits slim devices securely while allowing them to remain in complete contact with flat surfaces.
  • Flexible compatibility
    Offers flexible compatibility with select Kensington keying systems, so you can leverage Kensington custom keying solutions across your organization.
  • Pivot & rotate cable
    Fully rotating cable creates greater freedom of movement, eliminating awkward angles and allowing you to insert your key with complete ease.
Kensington ClickSafe 2.0 Keyed Laptop Lock - Standard Keyed - for Dell Devices - security cable lock
Security cable lock
Product Material
Carbon steel
Pivot adjustment, ClickSafe Security Anchor, cut-resistant, hidden pin, rotatable, Tough Lock Head lock
Europe
Security cable lock
Product Material
Carbon steel
Europe
