From the industry leader in physical device security for 25 years, Kensington's ClickSafe 2.0 Keyed Laptop Lock offers all the strength and one-click convenience and keyless engagement of the original, just in a smaller, uncompromised design. Featuring the 5mm keying system with anti-pick Hidden Pin Technology, the ClickSafe lock head snaps onto the ClickSafe Security Anchor after it has been installed into the Kensington Security Slot found in most laptops. A carbon steel cable deters cutting attempts and the pivot & rotate hinge prevents awkward angles when inserting the key.
 - Kensington ClickSafe 2.0 Keyed Laptop Lock - security cable
- Product Type
 - Security cable
- Product Material
 - Carbon steel
- Length
 - 1.8 m
 - Pivot adjustment, ClickSafe Security Anchor, cut-resistant, hidden pin, rotatable
 - Limited lifetime warranty
- Product Type
 - Security cable
- Product Material
 - Carbon steel
- Length
 - 1.8 m
 - Limited warranty: - lifetime
