Kensington ClickSafe 2.0 3-in-1 Keyed Laptop Lock (T-Bar, Nano & Wedge Anchors)
Quicklinx: G8PLWS00 Mfr#: K68102EU
Device Type: Laptop
Type: Security
Device Screen Size: [N/A]
Colour: Black, Silver
12 In Stock
£54.33 ex VAT
£65.19 inc VAT
The ClickSafe 2.0 Universal Keyed Laptop Lock fits any laptop security slot – standard T-bar, Nano or Wedge-Shaped – to lock down your laptop, regardless of brand or generation. From Kensington, inventor and worldwide leader in laptop security locks.
  • One lock for any slot
    Fits standard T-bar, nano, or wedge-shaped laptop security slots, regardless of brand or generation.
  • 5mm keying system with master keying option and custom keying solutions
    Common across all of Kensington's latest locks, so there's only one keying system to manage. Have one key open all locks; create supervisor-keyed and like-keyed versions.
  • ClickSafe locking technology
    Allows the lock head to be attached with one hand in a single click.
  • Patented Anti-Pick Hidden Pin technology and carbon steel cable
    Resists tampering and offers peace-of-mind. 1.8m (6 ft.) cable with plastic sheath delivers the same level of cut-resistance and theft-resistance as thicker cables.
  • Pivot and rotate cable
    A special hinge allows flexible movement and easy key insertion.
  • Verified & tested
    Each Kensington lock is precision engineered to meet or exceed rigorous industry standards for strength, physical endurance, and mechanical resilience.
Kensington ClickSafe 2.0 Universal Keyed Laptop Lock - security cable lock
Security cable lock
Product Material
Carbon steel
3 cm x 1.3 cm x 2.7 cm
Length
1.8 m
205 g
Tamper-proof, hidden pick-resistant pin
Europe
5-year warranty
Security cable lock
Product Material
Carbon steel
3 cm
1.3 cm
2.7 cm
Length
1.8 m
205 g
Europe
Security Cable Lock
Lock Type
T-Bar, wedge, nano
Lock Method
Key
Limited warranty: - 5 years
Device Type: Laptop
Type: Security
Colour: Black
Colour: Silver
Brand: Kensington
