The first wave of USB-C products are here and Kensington is making sure you have the adapter to keep your standard USB accessories up and running. The CA1000 USB-C to USB-A Adapter allows you to connect your USB-C device to a keyboard, mouse, hard drive or other peripheral accessory with a standard USB-A port. The adapter has a reversible connector and supports charging up to 3 AMPs. You can also transfer data up to 5 Gbps, and with Plug & Play installation, youll be connected quickly and easily.
- Kensington CA1000 - USB-C adapter - USB to 24 pin USB-C
- USB-C adapter
- Molded, sync and charge
- Connector
- 4 pin USB Type A - female
- Connector (Second End)
- 24 pin USB-C - male
- USB 3.1
- Black
- USB-C adapter
- Black
- Connector
- USB 3.1, Plug and Play, RoHS, halogen-free
