When youre on the road and need to power your device, the Kensington 10400 Mobile USB Charger is the perfect answer to boost a drained battery. The mobile charger features a 10,400 mAh battery and a 2.1 AMP output that has enough reserve power to fully charge an iPhone 6 Plus or a Galaxy S5 two times. The high-grade LG battery cell and high-quality components ensure your device charges safely and efficiently. With PowerWhiz Technology, the charger automatically detects your device and provides the fastest charge possible. A stylish aluminium cover finish creates a professional look and the 4-LED display lets you know how much power is left in the charger. The power bank can be used with a wide variety of devices including all Apple products, most Android smartphones and tablets, and many other USB-charged devices.
Powerful capacity
Powerful capacity when you need to charge your smartphone or tablet and there's no traditional outlet to get plugged in. Provides two full charges to an iPhone 6 Plus or a Galaxy S5. -
2.1 AMP output
Quickly charges tablets and smartphones at full speed so you can get your device's battery powered up and ready to go. -
PowerWhiz technology
An internal smartchip automatically detects your mobile device and provides the correct amps for a fast, safe charge so you can power up quickly. -
Aluminum finish
The stylish cover offers a premium look and feel that provides a level of sophistication that goes beyond the traditional black finish. -
4-LED display
The lights indicate how much battery power remains in the mobile charger so you know when it's time to refill the charger.
- Kensington Power Bank 10400 Mobile Charger power bank x 18650 - Li-Ion - USB
- Product Type
- Power bank
- 7.7 cm x 9.1 cm x 2.2 cm
- 255 g
- Silver
- Output Connector Type
- USB
- Voltage Required
- 5 V
- Voltage Provided
- 5 V
- Max Electric Current
- 2.1 A
- Battery
- 18650 - Lithium Ion - 10400 mAh
- Power Device Details
- - 5 pin Micro-USB Type B - 5 V - 1 A , - 4 pin USB Type A - 5 V - 2.1 A
- Cables
- USB charge cable
- Product Type
- Power bank
- Designed For
- Tablet, mobile phone
- 7.7 cm
- 9.1 cm
- 2.2 cm
- 255 g
- Enclosure Colour
- Silver
- Voltage Required
- 5 V
- Input Connectors
- Input Connectors Qty
- 1
- Voltage Provided
- 5 V
- Output connectors
- 4 pin USB Type A
- 2.1 A
- 5 pin Micro-USB Type B - 5 V - 1 A , 4 pin USB Type A - 5 V - 2.1 A
- PowerWhiz technology
- 18650
- Technology
- Lithium Ion
- Voltage Provided
- 5 V
- Capacity
- 10400 mAh
- LED power meter, circuit protection
- Cables Included
- USB charge cable
