Kensington Brushed Aluminium 2.1A 10400mAh USB Mobile Charger
Quicklinx: B5VXWS00 Mfr#: K38219WW
When youre on the road and need to power your device, the Kensington 10400 Mobile USB Charger is the perfect answer to boost a drained battery. The mobile charger features a 10,400 mAh battery and a 2.1 AMP output that has enough reserve power to fully charge an iPhone 6 Plus or a Galaxy S5 two times. The high-grade LG battery cell and high-quality components ensure your device charges safely and efficiently. With PowerWhiz Technology, the charger automatically detects your device and provides the fastest charge possible. A stylish aluminium cover finish creates a professional look and the 4-LED display lets you know how much power is left in the charger. The power bank can be used with a wide variety of devices including all Apple products, most Android smartphones and tablets, and many other USB-charged devices.
  • Powerful capacity
    Powerful capacity when you need to charge your smartphone or tablet and there's no traditional outlet to get plugged in. Provides two full charges to an iPhone 6 Plus or a Galaxy S5.
  • 2.1 AMP output
    Quickly charges tablets and smartphones at full speed so you can get your device's battery powered up and ready to go.
  • PowerWhiz technology
    An internal smartchip automatically detects your mobile device and provides the correct amps for a fast, safe charge so you can power up quickly.
  • Aluminum finish
    The stylish cover offers a premium look and feel that provides a level of sophistication that goes beyond the traditional black finish.
  • 4-LED display
    The lights indicate how much battery power remains in the mobile charger so you know when it's time to refill the charger.
Kensington Power Bank 10400 Mobile Charger power bank x 18650 - Li-Ion - USB
Power bank
7.7 cm x 9.1 cm x 2.2 cm
255 g
Silver
Output Connector Type
USB
5 V
Voltage Provided
5 V
Max Electric Current
2.1 A
18650 - Lithium Ion - 10400 mAh
Power Device Details
- 5 pin Micro-USB Type B - 5 V - 1 A , - 4 pin USB Type A - 5 V - 2.1 A
Cables
USB charge cable
Power bank
Tablet, mobile phone
7.7 cm
9.1 cm
2.2 cm
255 g
Enclosure Colour
Silver
5 V
Input Connectors
Input Connectors Qty
1
Voltage Provided
5 V
Output connectors
4 pin USB Type A
2.1 A
5 pin Micro-USB Type B - 5 V - 1 A , 4 pin USB Type A - 5 V - 2.1 A
Lithium Ion
Voltage Provided
5 V
10400 mAh
LED power meter, circuit protection
USB charge cable
