Designed exclusively for Surface Pro, the BlackBelt 2nd Degree Rugged Case for Surface Pro 7, 6, 5 & 4 is the ultimate case for protecting your Surface Pro. It features military-grade drop protection, cable lock compatibility and a two-year warranty. Other features include a self-adjusting hand strap that allows the device to lie flat, pen holder and tether, kickstand opening, keyboard holder and TypeCover strap.
- Kensington BlackBelt 2nd Degree Rugged Case for Surface Pro 7, 6, 5, & 4 - back cover for tablet
- Product Type
- Back cover for tablet
- 30.36 cm x 22.4 cm x 2.34 cm
- 260 g
- Material
- Silicone, PC/ABS, thermoplastic rubber (TPR)
- 2-year warranty
- Designed For
- Microsoft Surface Pro (Mid 2017), Pro 4, Pro 6, Pro 7
- 30.36 cm
- 22.4 cm
- 2.34 cm
- 260 g
- Rugged
- Material
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- Protection
- Drop-proof
- Cover Type
- Back cover
- Carrying Strap
- Hand strap
- Additional Compartments
- Pen/stylus holder
- Cover Features
- Stand function
- MIL-STD 810G
- 2 years
- Designed For
