Kensington Blackbelt Rugged Case For Surface Pro 7/6 with CAC Reader
Quicklinx: G7C7WS00 Mfr#: K97550WW
Secure and protect your Surface Pro, its data, and your network with the ultimate case - the BlackBelt Rugged Case with Integrated CAC Reader for Surface Pro 7+, 7, Surface Pro 6, Surface Pro (5th Gen) & Surface Pro 4. It features a FIPS 201-compliant CAC reader, military-grade drop protection, a protective camera cover, cable lock compatibility, and TAA compliance. Other features include a self-adjusting hand strap that allows the device to lie flat, pen holder and tether, kickstand opening, keyboard holder, TypeCover strap, an opening for I/O ports plus a USB 3.0 pass-through, and read-only memory.
  • Enhanced durability
    Crafted from silicone and thermoplastic polyurethane (TPU), the Kensington BlackBelt Rugged Case offers robust protection for the Surface Pro 7/6/5/4. Its rugged design is drop-proof, ensuring your tablet withstands the rigors of daily use.
  • Secure and functional
    Featuring an integrated CAC (Common Access Card) reader, this case meets FIPS 201 compliance, making it ideal for government and military personnel. The smart card reader adds an extra layer of security, while the stand function and hand strap enhance usability and comfort.
  • Optimal operating conditions
    Designed to operate in a wide range of temperatures, from -10°C to 40°C, the Kensington BlackBelt Rugged Case ensures your Surface Pro remains protected and functional no matter the environment.
Kensington BlackBelt Rugged Case with Integrated CAC Reader for Surface Pro 7/6/5/4 - protective case for tablet
Protective case for tablet
22.3 cm x 2.6 cm x 30.3 cm
320 g
Material
Silicone, thermoplastic polyurethane (TPU)
Microsoft Surface Pro (Mid 2017), Pro 4, Pro 6, Pro 7
22.3 cm
2.6 cm
30.3 cm
320 g
Rugged
Material
Lining Material
Polycarbonate
Carrying Case
Protective case
Recommended Use
For tablet
Protection
Drop-proof
Carrying Strap
Hand strap
Additional Compartments
Pen/stylus holder
Cover Features
Stand function, smart card reader
MIL-STD 810G, FIPS 201
Min Temperature
-10 °C
Max Temperature
2 years
