The Surface Go is the next generation of laptop replacements, offering an incredible combination of productivity and portability. Valuable mobile investments need to be protected to prevent damage and the cost of replacement. Kensington's designers have worked closely with Microsoft as a member of the Designed for Surface programme to adapt the BlackBelt Rugged Case for Surface Go. It surrounds the Surface Go in military-grade drop protection with an integrated hand strap for worry-free carrying. The Type Cover easily attaches and detaches without removing the protective case, and a form-fitting Surface Pen holder and tether keeps the pen handy. The BlackBelt Rugged Case's strategic cut-outs preserve unobstructed access to the Surface Go's kick stand, buttons, ports and camera.
                Military-grade protectionA strong, rugged TPU body surrounds the Surface Pro and Surface Pro 4 and meets the MIL-STD-810G testing protocols for drop protection.
                "Designed for Surface" programKensington is an official participant in Microsoft's "Designed for Surface" program, which helps 3rd-party manufacturers create exceptional accessories that work seamlessly with Surface devices.
                Hand strapConstructed of flexible silicone to fit a wide variety of hand sizes, it provides a convenient and worry-free way to hold the tablet when you're sharing or collaborating, especially if you're in a highly mobile environment.
                Type cover channelAllows you to quickly and easily attach or detach the Type Cover without having to remove the rugged case from the Surface Pro and Surface Pro 4.
                QuickFold designIdeal for mobile viewing, the Type Cover can be folded down and around the backside of the rugged case so the keyboard is neatly out of the way without having to detach it.
- Kensington BlackBelt Rugged Case for Surface Go - protective case for tablet
- Product Type
- Protective case for tablet
- 18.84 cm x 27.06 cm x 2.1 cm
- 174 g
- Localisation
- Europe
- Material
- Silicone, polycarbonate, thermoplastic polyurethane (TPU)
- Black
- 2-year warranty
- Designed For
- Microsoft Surface Go, Go 2
- 18.84 cm
- 27.06 cm
- 2.1 cm
- 174 g
- Rugged
- Material
- Black
- Localisation
- Europe
Carrying Case
- Protective case
- Recommended Use
- For tablet
- Protection
- Scratch-resistant, drop-proof
- Carrying Strap
- Hand strap
- Additional Compartments
- Pen/stylus holder
- Cover Features
- Stand function
- MIL-STD 810G
- 2 years
- Designed For
