Kensington 23.6" Privacy Filter 2-way Removable
Quicklinx: FP0ZWS00 Mfr#: 627205
Accessory Type: Privacy Screen
12 In Stock
£59.88 ex VAT
£71.85 inc VAT
Kensington Privacy Screen Filters reduce the risk of unwittingly sharing confidential data with an unwanted viewer. Available for monitors, laptops and tablets, privacy filters keep users productive without the need to adjust positions in order to shield their screen from prying eyes.
Key Features:
  • Limits viewing angle to 30° and keeps your sensitive information safe
  • Blue Light Reduction: reduces detrimental blue light by up to 42%, easing eye strain and promoting natural sleep
  • Innovative anti-glare coating reduces reflection and improves clarity
  • Anti-fingerprint coating keeps your screen clean and free of greasy marks
  • Edge to edge alignment for perfect fit with your screen
  • 23.6" Wide 16:9 Monitor
  • 2-way removable
  • 23.6"
  • Blue light reduction
    Filters out the harmful rays by up to 30%, easing eye strain and reducing the chances of blue light interrupting your natural sleep patterns.
  • Installation options
    The privacy screen can be mounted either with the included frameless tab holders that attach to the edges of your monitor, letting you quickly and easily insert or remove the privacy screen, or you can mount it with double-sided tape that adheres directly to the screen for a cleaner look.
  • Anti-reflective coating
    Reduces glare from any outside light sources that can interfere with your viewing clarity.
  • Reversible viewing
    Either side of the privacy screen can be used to different effect. One side has a matte finish to maximize glare reduction, is smooth to the touch and reduces traces of fingerprints. The other side is glossy and provides a clearer view of the monitor screen.
Kensington display privacy filter - 23.6"
Display privacy filter - 2-way
Installation Type
Removable
Display Screen Size Compatibility
23.6"
23.6"
Display Filter
Privacy Protection
2-way
Installation Type
Removable
Aspect Ratio
16:9
Brand: Kensington
