Protect the sensitive information on your monitor with a Kensington Privacy Filter. Block wandering eyes and keep your data protected.
Enhanced privacy
The 2-way privacy protection ensures that your screen is visible only to you, preventing others from viewing your sensitive information from the sides. -
Easy to use
Designed to be removable, this display privacy filter offers the flexibility to easily attach and remove as needed, providing convenience and protection on-the-go.
- Kensington - display privacy filter
- Product Type
- Display privacy filter - 2-way
- Installation Type
- Removable
- Display Screen Size Compatibility
- 21.5" wide
- Product Type
- 21.5" wide
Display Filter
- Privacy Protection
- 2-way
- Installation Type
- Removable
- Aspect Ratio
- 16:9
