Kensington 21.5" Privacy Filter 2 Way Removable
Quicklinx: FBWCWS00 Mfr#: 626482
Device Type: Monitor
Type: Privacy Screen
Device Screen Size: 21.5
Colour: Transparent
Hurry, only 1 left in stock!
£56.07 ex VAT
£67.28 inc VAT
Protect the sensitive information on your monitor with a Kensington Privacy Filter. Block wandering eyes and keep your data protected.
  • Enhanced privacy
    The 2-way privacy protection ensures that your screen is visible only to you, preventing others from viewing your sensitive information from the sides.
  • Easy to use
    Designed to be removable, this display privacy filter offers the flexibility to easily attach and remove as needed, providing convenience and protection on-the-go.
Kensington - display privacy filter
Display privacy filter - 2-way
Installation Type
Removable
Display Screen Size Compatibility
21.5" wide
21.5" wide
Display Filter
Privacy Protection
2-way
Installation Type
Removable
Aspect Ratio
16:9
Colour: Transparent
Brand: Kensington
