Protect the sensitive information on your monitor with a Kensington Privacy Filter. Block wandering eyes and keep your data protected.
                Enhanced privacyThe 2-way privacy protection ensures that your screen is visible only to you, preventing others from viewing your sensitive information from the sides.
                Easy to useDesigned to be removable, this display privacy filter offers the flexibility to easily attach and remove as needed, providing convenience and protection on-the-go.
- Kensington - display privacy filter
- Product Type
- Display privacy filter - 2-way
- Installation Type
- Removable
- Display Screen Size Compatibility
- 21.5" wide
- Product Type
- 21.5" wide
Display Filter
- Privacy Protection
- 2-way
- Installation Type
- Removable
- Aspect Ratio
- 16:9
