Kensington 2.4 Ghz Wireless presentation remote
Customer rating: 5.0* (Write a review)
Quicklinx: 49T5WS00 Mfr#: 33374EU
Accessory Type: Remote Control
Hurry, only 2 left in stock!
£22.64 ex VAT
£27.16 inc VAT
The tactile Presenter simplifies the task of delivering perfect presentations, to your audience and to your laptop with some very smart features.
Its 2.4Ghz wireless receiver not only prevents interference from other wireless devices but also stows safely away in the presenter when not in use. When the receiver is stowed in the Presenter a Smart power function prevents accidental power consumption, helping to safeguard against embarrassing battery life issues during presentations.
Kensington Si600 Wireless Presenter with Laser Pointer presentation remote control - black
Presentation remote control
Enclosure Colour
4.4 cm x 10.2 cm x 1.9 cm
Europe
Radio
Supported Devices
Personal computer
Buttons Qty
4 buttons
Max Operating Distance
20 m
2 x standard - AAA type
1-year warranty
4.4 cm
10.2 cm
1.9 cm
Enclosure Colour
Europe
Radio
Supported Devices
Personal computer
Buttons Qty
4 buttons
20 m
Built-in laser pointer
Operating System
Apple Mac OS, MS Windows 7, Windows 8
USB receiver, 2 AAA batteries
Included Qty
2
Limited warranty - 1 year
Resources
The following resources are available for the Kensington 2.4 Ghz Wireless presentation remote
Customer reviews
Write a review for the Kensington 2.4 Ghz Wireless presentation remote here!
Excellent
Reviewed by Anonymous Review Posted 18/06/2008
Great - It's wireless range is excellent so you can walk all over the place and it won't let you down. Also the usb stick is truly plug n play no software and it slides into the presenter so you can't lose it and this disconnects the battery so it never gets drained when buttons are pressed in your bag. Powerpoint backwards! forwards and blank screen is so relibale you can literally forget you are using it. You'll never use a wireless mouse again!
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Excellent product
Reviewed by Ross. Review Posted 16/05/2008
Excellent presenter tool, very ergonomic, comfortable to hold, nice rubberised plastic makes it easy to grip. Buttons have a positive click.
Lack of software is a bonus - just plug in and off you go. The forward and back buttons are effectively Pg Up and Pg Down, stop is Esc, and the laser pointer button also hits F5 to start the presentation. This does have a drawback if you want to use the laser pointer on a webpage, as it will keep refreshing the page!
Range is excellent, even with the PC and USB receiver tucked away in a cupbard. The USB receiver slots very neatly into the bottom of the device, which also turns it off to save battery power.
For £27, you can't say no!
  • Overall 5*
  • Ease of use 4*
Amazingly good!
Reviewed by Michael. Review Posted 31/01/2008
I've used on of these for several presentations and I can't rate it more highly for how good it is. It has always been reliable and battery life is excellent. It fits very well into the hand for comfortable use and the buttons feel nice and solid.
The range is excellent. I had my laptop in a cinema projection box and could drive the presentation from the lectern in the auditorium about 45-50m away through the wall!
The usb dongle installs automatically without any driver discs etc. on any Win XP computer and is ready to go in about 5-6 seconds. The best bit is that it is stored inside the transmitter and when stowed turns the unit off so you can't drain the battery with buttons pressed in your bag/pocket.
All this for under £25 - Bargain!
  • Overall 5*
  • Ease of use 5*
Read all 5 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Brand: Kensington
