The contour panel is engineered to bring weight closer to the body o reduce shoulder and back fatigue by up to 35%.
- Kensington Contour Overnight Notebook Roller - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- 1680D ballistic nylon
- 400 mm x 230 mm x 500 mm
- 3.4 kg
- Notebook Compatibility
- 17"
- 3-year warranty
- Product Type
- Product Material
- 400 mm
- 230 mm
- 500 mm
- 3.4 kg
- 17"
- Notebook Compatibility Dimensions
- 40.6 cm x 29.2 cm x 3.8 cm
- Black
- Limited warranty: - 3 years
