Kensington 125cm Portable Desktop Screen
Quicklinx: 6KVKWS00 Mfr#: 1901954
This almost magical carry case turns into a full-sized projection screen in less than 5 seconds. The lightweight aluminium design is ideal for the travelling presenter or for use in meeting rooms where a screen cannot be attached to the wall. To set-up: swivel the feet of the integrated case to the front, release the catches and open case and then simply pull the screen up to the desired height. The pressurised air system behind screen gives it maximum stability and requires no fastening. To put away: simply push back down the screen into the integral robust carry case.
NOBO projection screen with desk stand - 49" (125 cm)
Projection screen with desk stand
Projection Screen Image Diagonal Size
49" (125 cm)
Projection Image Size
99.6 cm x 75 cm
Aspect Ratio
4:3
96 cm x 14 cm x 14 cm
2.92 kg
1-year warranty
Image Diagonal Size
49" (125 cm)
Image Width
99.6 cm
Image Height
75 cm
Aspect Ratio
4:3
96 cm - 14 cm - 14 cm
2.92 kg
Limited warranty - 1 year
