With a recording resolution of 1080p HD at 30 frames per second and a wide-angle field of view at 150 degrees, the X100 Action Camera consistently produces clear, focused footage that is fantastic to view. The X100 Action Camera with Wi-Fi lets you view, download and share your footage with ease and the Wrist Remote allows for control of recording without having to play around with the setup of the X100.
The X100 Action Camera with W-iFi lets you view, download and share your footage with ease and the wrist remote allows for control of recording without having to play around with the setup of the X100.
Waterproof case
Take your X100 with you everywhere you go, whether you're on the ground, in the sky or underwater. The Waterproof case will keep your camera dry in any situation up to a depth of 30 m. -
Full HD video
Capture your experiences in 1080p and get the most out of your X100. Watch your footage on TV via the mini HDMI port. -
Wi-Fi connectivity
Use your smart device to frame up your shots and playback footage with the X100 app so you never go home uncertain. -
Built-in display
The X100 comes fitted with a 2-inch LCD screen so you can perfectly frame your shots. Built with clarity in mind, the X100 won't ever leave you stuck with over-saturated footage or stills.
- Kaiser Baas X100 - action camera
- Product Type
- Action camera - 1080p
- Action Camera Type
- Mountable
- Memory Card Slot
- microSD card
- Wireless Interface
- Wireless LAN
- Sensor Resolution
- 5.0 MP
- Max Video Resolution
- 1920 x 1080
- Lens System
- Wide-angle lens 2.65 mm f/2.5
- Focus Adjustment
- Focus free
- Min Focus Distance
- 50 cm
- Display
- LCD display - 2"
- Supported Battery
- Li-ion rechargeable battery - 1060 mAh (included)
- Interface
- HDMI, USB 2.0
- 5.4 cm x 3.7 cm x 5.1 cm
- 77 g
- Product Type
- Camcorder Sensor Resolution
- 5.0 MP
- Camcorder Interpolated Photo Resolution
- 12.0 MP
- Widescreen Video Capture
- Optical Sensor Type
- CMOS
- Optical Sensor Size
- 1/2.5"
- Frame Rate (Max Resolution)
- 30 fps
- Digital Video Format
- H.264, MOV
- Image Recording Format
- JPEG
- 1920 x 1080
- Interface
- HDMI, USB 2.0, Wireless LAN
Exposure & White Balance
- Light Sensitivity
- ISO auto (100-200)
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Fluorescent, cloudy, tungsten light, daylight, fluorescent light (warm white)
- Max Shutter Speed
- 1/2000 sec
- Min Shutter Speed
- 1/30 sec
Lens System
- Wide-angle lens 2.65 f/2.5
- Focus Adjustment
- Focus free
- 50 cm
- Max View Angle
- 150 degree(s)
Additional Features
- Self-Timer Delay
- Additional Features
- Auto power save, date/time stamp, Time-Lapse recording, Loop recording
Action Camera Features
- Camera Type
- Mountable
- Time-Lapse recording
Display
- 2" LCD display
- Display Form Factor
- Built-in
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB , HDMI output
- Included Accessories
- USB cable, mounting screw, underwater housing, curved adhesive mount, 2 adhesive pads, flat adhesive mount, remote control wristband, quick release mount
- Protection
- Waterproof
- Underwater Use
- Underwater Depth
- Up to 30 m
- Battery Type
- Lithium Ion - manufacturer-specific
- Details
- Battery Life Details
- Video recording - 1.33 hours
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card, microSDHC Card
- Memory Card Included
- No
- Memory Card Max Supported Size
- 32 GB
- Video Capture
- 1920 x 1080 p - 30 fps , 1280 x 720 p - 60 fps , 1280 x 720 p - 30 fps
- 5.4 cm
- 3.7 cm
- 5.1 cm
- 77 g
