Capture stunning footage with the X80 everywhere you go. Your adventures and experiences are worth capturing. From holidays with family and friends to bike rides, swimming lessons and trips to the beach.
Waterproof up to 30m With the supplied X80 accessory kit, you ready to capture the action. On the ground, in the air or underwater to a depth of 30m.
Easy to use
With a simple two button operation, the X80 is the perfect camera to get you recording those moments at quick notice, so you don’t miss a thing. With the waterproof housing and a selection of mounts already included, you’re ready to go.
Full HD Video Capture motion video at full HD resolution: 1080p @ 30fps. Play the video directly from the X80 to your TV via the built in HDMI port. The X80 offers 5MP photos using its ultra wide 120° lens.
Snapshots with One Click Don’t miss out on crucial moments! The simple two button operation means you can toggle between video and photo modes quickly and easily.Simple two button operation means you can toggle between video and photo modes quickly and easily so you don’t miss crucial moments.
Built-in display The X80 comes fitted with a digital 2-inch screen so you can perfectly frame your shots and videos. Built with clarity in mind, the X80 won’t ever leave you stuck with over-saturated footage or stills.
Take it outdoors Mount your X-Series Action Camera or GoPro to your bike, or your car, even on your chest or helmet
Waterproof up to 30 m
With the supplied X80 accessory kit, you're ready to capture the action. On the ground, in the air or underwater up to a depth of 30 m. -
Easy to use
With simple two button operation, the X80 is the perfect camera to get you recording those moments at quick notice, so you don't miss a thing. -
Full HD video
Capture footage at full HD resolution. Play the video directly from the X80 to your TV via the built in mini HDMI port. The X80 offers 5MP photos using its wide 120° lens. -
Snapshots with one click
Don't miss out on crucial moments! The simple two button operation means you can toggle between video and photo modes quickly and easily. Simple two button operation means you can toggle between video and photo modes quickly and easily so you don't miss crucial moments. -
Built-in display
The X80 comes fitted with a 2-inch LCD screen so you can perfectly frame your shots. Built with clarity in mind, the X80 won't ever leave you stuck with over-saturated footage.
- Kaiser Baas X80 - action camera
- Product Type
- Action camera - 1080p
- Action Camera Type
- Mountable
- Memory Card Slot
- microSD card
- Sensor Resolution
- 5.0 MP
- Max Video Resolution
- 1920 x 1080
- Lens System
- Wide-angle lens 3.1 mm f/2.8
- Focus Adjustment
- Focus free
- Min Focus Distance
- 50 cm
- Display
- LCD display - 2"
- Supported Battery
- Li-ion rechargeable battery - 1600 mAh (included)
- Interface
- HDMI, USB 2.0
- 5.4 cm x 2.6 cm x 5.1 cm
- 90 g
- Product Type
- Camcorder Sensor Resolution
- 5.0 MP
- Camcorder Interpolated Photo Resolution
- 12.0 MP
- Widescreen Video Capture
- Optical Sensor Type
- CMOS
- Optical Sensor Size
- 1/2.5"
- Digital Video Format
- H.264, MOV
- Image Recording Format
- JPEG
- 1920 x 1080
- Interface
- HDMI, USB 2.0
Exposure & White Balance
- Light Sensitivity
- ISO auto (100-200)
- White Balance
- Automatic, presets
- Max Shutter Speed
- 1/2000 sec
- Min Shutter Speed
- 1/30 sec
Lens System
- Wide-angle lens 3.1 f/2.8
- Focus Adjustment
- Focus free
- 50 cm
- Max View Angle
- 120 degree(s)
Additional Features
- Additional Features
- Date/time stamp, Time-Lapse recording, Loop recording
Action Camera Features
- Camera Type
- Mountable
- Time-Lapse recording
Display
- 2" LCD display
- Display Form Factor
- Built-in
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB , HDMI output
- Included Accessories
- USB cable, mounting screw, underwater housing, curved adhesive mount, 2 adhesive pads
- Protection
- Waterproof
- Underwater Use
- Underwater Depth
- Up to 30 m
- Battery Type
- Lithium Ion - manufacturer-specific
- Details
- Battery Life Details
- Video recording - 1.33 hours
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card, microSDHC Card
- Memory Card Included
- No
- Memory Card Max Supported Size
- 32 GB
- Video Capture
- 1920 x 1080 p - 30 fps , 1280 x 720 p - 60 fps , 640 x 480 - 120 fps
- 5.4 cm
- 2.6 cm
- 5.1 cm
- 90 g
