Featuring dual lenses, the X360 is the ultimate user friendly 360º camera. Use the smartphone app to control the X360 remotely and preview your shots to always get the perfect footage.
Capture the world through dual lens
Explore the world unlike never before; in full 360-degree views. Capture unbelievable vision through the X360 dual lens, relive your experiences in virtual reality or share your footage for the world to see on the Internet. The front and rear lenses each capture 180-degrees horizontally and vertically, creating a seamless and complete 360-degree field of view. -
Make your own virtual reality HD videos
The X360 videos are watchable trough the VR-X headset. Because of this, the X360 could be just what content creators need to start making quality 360-degree video. -
Pair up your smartphone via Wi-Fi
You can watch, pan around and share your content from your smartphone or tablet. -
Lightweight design
Compact in design and lightweight, the X360 Dual Lens VR camera's dome shaped lenses allows the user to record footage in 360-degree panorama mode, ensuring you to capture every moment, of every experience, from every conceivable angle.
- Kaiser Baas X360 Dual Lens VR - action camera
- Product Type
- Action camera - compact
- Action Camera Type
- Mountable
- Memory Card Slot
- microSD card
- Wireless Interface
- Wireless LAN
- Sensor Resolution
- 2 x 4.0 Megapixel
- Max Video Resolution
- 1920 x 960
- Lens System
- 2 x fisheye lens 1.1 mm f/2.0
- Display
- LCD display - 1.5"
- Supported Battery
- Li-ion rechargeable battery - 1500 mAh (included)
- Interface
- USB 2.0
- 6 cm x 5 cm x 4.8 cm
- 106 g
- Product Type
- Sensor Resolution
- 2 x 4.0 Megapixel
- 360° Camera
- Optical Sensor Type
- CMOS
- Digital Video Format
- H.264, MOV
- Image Recording Format
- JPEG
- 1920 x 960
- Interface
- USB 2.0, Wireless LAN
- Connectivity Features
- Remote control via mobile devices, remote live view, Wireless Image Transfer
Lens System
- 2 x fisheye lens 1.1 f/2.0
- Max View Angle
- 180 degree(s)
Additional Features
- Additional Features
- Auto power save
Action Camera Features
- Camera Type
- Mountable
360° Camera
- Optical Sensor Qty
- 2
Display
- 1.5" LCD display
- Display Form Factor
- Built-in
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB
- Included Accessories
- Cleaning cloth, tripod, USB cable, tripod adapter, curved adhesive mount, flat adhesive mount, quick release mount, carrying bag
- Battery Type
- Lithium Ion - integrated
- Details
- Battery Life Details
- Video recording - 1.33 hours
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card, microSDHC Card
- Memory Card Included
- No
- Memory Card Max Supported Size
- 32 GB
- Image Storage
- JPEG 3008 x 1504
- Video Capture
- H.264 - 1920 x 960
- 6 cm
- 5 cm
- 4.8 cm
- 106 g
