Kaiser Baas Alpha Drone
Quicklinx: CL5CWS00 Mfr#: KBA15001
The Alpha Drone is the next evolution in camera accessories. Enjoy honing your flight skills and capture amazing HD footage and stills from the air. Light-weight at just 109g and with a streamlined body 33cm in diameter, the Alpha Drone was designed for aerial acrobatics to capture even more exciting footage. The Alpha Drone is completely stable in flight thanks to its in-built 6-axis gyroscopic control giving the Alpha superior stabilisation, even against wind and tricky manoeuvres.
Use the Alpha Drone Transmitter and its display screen to trim and tweak the controls. Trigger the photo, video and 3D Eversion functions at the touch of a button. With a range of over 60m, even if the Alpha flies out of range, there’s no need to worry about lost footage as the on-board camera records locally to a Micro SD card (included) and won’t stop if the Alpha travels too far from the Transmitter. The on-board camera records footage in HD 720p at 30 frames per second and shoots pictures at 2MP. Switch easily between modes with the buttons on the Alpha Drone Transmitter.
Alpha Drone Key Features
  • PowerPlant : Quad 4V 1.9A 40,000 RPM B.Motors X4
  • Length / Height: 33.1mm X 331.1mm
  • Weight: 109g
  • Range: 60 Metres
  • Camera: HD 720p 30fps
  • Recording: 2G Micro SD Card
  • Black Box Recorder: HD 720p camera records locally, even when out of range
  • Playback: USB Micro SD Card
  • Stabilisation: 6-Axis Gyro control; levels drone and protects against bumps
  • Controller: 2.4Ghz 4 Channel; 6x AA batteries(not included)
  • Controller Display: Battery level; signal strength; channel; trimming settings; drone lights; Acceleration %
  • 3D Eversion: One-button aerial flip function
  • Battery: Rechargeable 550mAh
  • Spare Parts: Full set of spare blades; Phillips head screwdriver
Kaiser Baas Alpha Drone - quadcopter
