Juice PowerBank 5 Black - 15,000mAh with USB-C
Quicklinx: FT6BWS00 Mfr#: JUI-PBANK-5-BLK
Type: Rechargeable
£29.16 ex VAT
£34.99 inc VAT
The Juice 5 Charge Power Bank with 15,000mAh (Five Full Charges) battery capacity. With the Juice 5, we head into festival territory. If you are away for 4-5 days camping, or anywhere away from mains power, the Juice 5 Charge Power Bank has you and your pals covered. With 5 full charges you don't need to stress about running out of power over a longer period.
Features:
Holds Five Full Charges Charge Two Devices at Once (USB Type-And and USB Type-C Outputs) 0-50% Charge in 50 Minutes Compact / Lightweight Design Digital Battery Level Display
Juice 5 power adapter - USB, 24 pin USB-C
Power adapter
6 cm x 3 cm x 14 cm
313 g
Output Connector Type
Total 2: USB, 24 pin USB-C
5 V
Voltage Provided
DC 5 V
Max Electric Current
2.4 A
15000 mAh - 55.5 Wh
Power adapter
Tablet, mobile phone
6 cm
3 cm
14 cm
313 g
Enclosure Colour
5 V
Input Connectors
5 pin Micro-USB Type A, 24 pin USB-C
Input Connectors Qty
2
Voltage Provided
DC 5 V
Output connectors
Total 2: 4 pin USB Type A, 24 pin USB-C
2.4 A
Battery status display
15000 mAh - 55.5 Wh
Type: Rechargeable
Brand: Juice
