Juice 1m Lightning Charge and Sync Cable - White
Quicklinx: FSQQWS00 Mfr#: CABLE-LIGHT-1M-RND-WHT
Charge your iPhone or iPad with the 1 metre ECO Juice Apple Lightning Cable. No need to stick with just White, add some colour to your life.
It is a must have for all of your iPhone & iPad charging needs. The Juice MFI Approved lightning charge and sync cable is compatible with all iPhones, Air Pods & iPads from iPhone 5 & iPad 4's generation onwards, all the way up to the latest iPhone 14.
The Juice ECO Cables are now made from TPE, which produces less carbon to produce than traditional PVC cables.
Juice Lightning cable - 1 m
Cable
Lightning cable
Length
1 m
White
Connector
Lightning - male
Connector (Second End)
USB - male
Sync and charge
Cable Type
Lightning cable
Length
1 m
Sync and charge
White
Connector
Apple Lightning - male
4 pin USB Type A - male
MFI
40 g
