Here at Juice we only use MFI Approved lightning chips, ensuring every one of our cables works perfectly every time.
The Juice Lightning Cable is a must have for all of your iPhone & iPad charging needs. The Juice MFI Approved Lightning charge and sync cable is compatible with all iPhones & iPads.
- Juice Lightning cable - 1 m
- Cable
- Lightning cable
- Length
- 1 m
- White
- Connector
- Lightning - male
- Connector (Second End)
- USB - male
- Sync and charge
- Designed For
- Apple 10.2-inch iPad; 10.5-inch iPad Air; 10.5-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; 4; 5; iPad with Retina display; iPhone 11, 5, 5c, 5s, 6, 6s, 7, 8, SE, X, XR, XS, XS Max; iPod nano; iPod touch
- Cable Type
- Lightning cable
- Length
- 1 m
- Sync and charge
- White
- Connector
- Apple Lightning - male
- 4 pin USB Type A - male
- MFI
- 40 g
- Designed For
- Apple 10.2-inch iPad (7th generation, 8th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro , Apple 12.9-inch iPad Pro (1st generation, 2nd generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPad mini 5 , Apple iPad with Retina display (4th generation) , Apple iPhone 11, 11 Pro, 11 Pro Max, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, SE (2nd generation), X, XR, XS, XS Max , Apple iPod nano (7G) , Apple iPod touch (5G, 6G, 7G)
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
FSQQ 043957 Condition: Customer return - item has been used and shows signs of use. Not in original packaging. |
£2.99 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
