Specification:
Connection: USB A
Drive free: Plug and play
System requirements: Windows 2000, Windows XP, Windows Vista TM, Windows 7, Windows 8 and Windows 10
Compatible with Microsoft software such as Skype
Adjustable headphone and microphone volume
Noise cancelling Microphone
Microphone sensitivity: 40±3dB (0dB=1V/Pa at 1KHz)
Headphone Impedance: 150 ohms
Headphone frequency range: 100-6600HZ
Headphone sensitivity: 100±3dB
Environmental noise: = 60dB(A)
Lightweight and comfortable to wear
Meets the international standards for hearing protection (Less than 118db).
- JLC Motion Stereo - headset
- Product Type
- Headset - wired - USB-A
- Compatibility
- Windows
- Recommended Use
- Computer
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 100 - 6600 Hz - Sensitivity 100 dB +/- 3dB
- Impedance
- 150 Ohm
- Microphone
- Boom
- Microphone Noise Cancelling
- Controls
- Volume, microphone volume
- Product Type
- Compatibility
- Windows
- Recommended Use
- Computer
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Stereo
- 100 - 6600 Hz
- Sensitivity
- 100 dB +/- 3dB
- Impedance
- 150 Ohm
Microphone
- Boom
- Form Factor
- Headset microphone
- Sensitivity
- -40 dB
- Noise Cancelling
Remote Control
- Controls
- Connector Type
- USB (4 PIN USB Type A)
- Cable Details
- USB cable
