JL Corporate JLC Motion Stereo USB Headset
Quicklinx: FSTRWS00 Mfr#: MOTSUSBHS
Specification:
Connection: USB A
Drive free: Plug and play
System requirements: Windows 2000, Windows XP, Windows Vista TM, Windows 7, Windows 8 and Windows 10
Compatible with Microsoft software such as Skype
Adjustable headphone and microphone volume
Noise cancelling Microphone
Microphone sensitivity: 40±3dB (0dB=1V/Pa at 1KHz)
Headphone Impedance: 150 ohms
Headphone frequency range: 100-6600HZ
Headphone sensitivity: 100±3dB
Environmental noise: = 60dB(A)
Lightweight and comfortable to wear
Meets the international standards for hearing protection (Less than 118db).
JLC Motion Stereo - headset
Headset - wired - USB-A
Compatibility
Windows
Recommended Use
Computer
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 100 - 6600 Hz - Sensitivity 100 dB +/- 3dB
Impedance
150 Ohm
Microphone
Boom
Microphone Noise Cancelling
Controls
Volume, microphone volume
Compatibility
Windows
Recommended Use
Computer
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Frequency Response
100 - 6600 Hz
Sensitivity
100 dB +/- 3dB
Impedance
150 Ohm
Microphone
Boom
Headset microphone
Sensitivity
-40 dB
Noise Cancelling
Remote Control
Controls
Connector Type
USB (4 PIN USB Type A)
Cable Details
USB cable
