JBL Xtreme 4 - Black
Quicklinx: HX9VWS00 Mfr#: JBLXTREME4BLKUK
19 In Stock
£207.50 ex VAT
£249.00 inc VAT
Live Loud: Take your listening experience to the next level with the JBL Xtreme 4 Bluetooth speaker, featuring amazing sound and easy portability courtesy of the convenient shoulder strap
JBL Pro Sound: Dual pumping JBL Bass Radiators and two woofers and drivers provides clear sound with deep bass and plenty of detail, delivering truly unique audio immersion
Ultimate Protection: Thanks to its waterproof and dustproof rating, this powerful speaker handles almost any environment: from beach picnics to pool parties
Keep the Good Times Going: The built-in power bank charges your devices while playing; with up to 24 hours of battery life, enjoy the music until the sun goes down
  • Robust battery life
    With a 9444 mAh lithium-ion rechargeable battery, enjoy up to 15 hours of non-stop music. The battery's high-capacity ensures you can listen to your favorite tunes all day, and with a quick recharge time of just 3.5 hours, your speaker is ready to go when you are.
  • Exceptional sound quality
    Experience JBL Pro Sound with a frequency response of 44 - 20,000 Hz and a signal-to-noise ratio of 80 dB. The speaker's 2-way crossover channel and integrated amplifier deliver clear, powerful sound, while the AI Sound Boost enhances audio quality in real-time.
  • Durable and portable design
    Designed for portable use, this speaker boasts IP67 protection, making it both dustproof and waterproof. Its rugged construction ensures it can withstand the elements, making it perfect for outdoor adventures.
  • Advanced connectivity
    Featuring Bluetooth 5.3 with auracast multi-speaker support, this speaker allows for seamless wireless connections and the ability to link multiple speakers for an immersive audio experience. The USB Type-C connection offers convenient charging and power bank functionality.
  • Intuitive controls and app integration
    Easily manage your music with play/pause, power on/off, and volume controls. The speaker is also app-controlled, allowing for effortless operation and access to additional features for an enhanced listening experience.
JBL - speaker - for portable use - wireless
Speaker - for portable use
Enclosure Design
Passive radiator
Speaker Type
Active
Amplifier
Integrated
Speaker battery rechargeable
Enclosure Design
Passive radiator
Speaker System
Speaker Type
Active
Amplifier
Integrated
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Power Source
Rechargeable
Capacity (Wh)
68 Wh
Brand: JBL
