JBL Wave Flex True Wireless Earbuds Blue
Quicklinx: HWZ0WS00 Mfr#: JBLWFLEXBLU
Type: Headphones
Connectivity: Wireless
Colour: Blue
£37.49 ex VAT
£44.98 inc VAT
Bring your sound everywhere. With bass you can feel, up to 32 total hours of battery life, and a secure, comfortable stick-open design, the splash and dust resistant JBL Wave Flex are designed for daily entertainment. Whether you're roaming city streets or relaxing on the beach, your hands-free stereo calls will always be crystal clear, while Smart Ambient technology keeps you aware of your surroundings and when you need an extra boost, you can speed charge two additional hours of power in just 10 minutes.
With 8 hours of battery life in the earbuds and 24 in the case, the JBL Wave Flex provide all day audio and when you need more power, you can speed charge an extra two hours in just 10 minutes.
When you're making hands-free stereo calls on the go, VoiceAware lets you balance how much of your own voice you can hear while talking with others. Get the most from your mixes with high-quality audio from secure, reliable earbuds with 12mm drivers featuring JBL deep bass sound.
From the beach to the bike trail, the IP54-certified earbuds and IPX2 charging case are water and dust resistant for all-day experiences.
  • JBL Deep Bass Sound
    Get the most from your mixes with high-quality audio from secure, reliable earbuds with 12mm drivers featuring JBL Deep Bass Sound.
  • Comfortable fit
    The ergonomic, stick-open design of the JBL Wave Flex fits so comfortably you may forget you're wearing them. The stick-open design allows you to enjoy all the sound without blocking your ear-canal.
  • Long battery life with speed charging
    With long battery life in the earbuds and more in the case, the JBL Wave Flex provide all-day audio. And when you need more power, you can speed charge an extra two hours in just 10 minutes.
JBL Wave Flex - true wireless earphones with mic
True wireless earphones - Bluetooth
Recommended Use
Portable electronics
Blue
Headphones Form Factor
In-ear
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.2
Sound Output Mode
Stereo
Sound Effects
Deep Bass
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 105 dB
Impedance
16 Ohm
True wireless earphones - Bluetooth - wireless
Dimensions & Weight Details
Earbud: 7.6 g , Charging case: 35.1 g
Blue
Recommended Use
Protection
Dust-resistant, splash-resistant
Audio Output
In-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.2
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Hands-Free Profile (HFP)
Sound Output Mode
Stereo
Sound Effects
Deep Bass
Frequency Response
20 - 20000 Hz
Sensitivity
105 dB
Impedance
16 Ohm
Diaphragm
12 mm
Microphone
Built-in
USB-C charging cable, charging case
IP54
Run Time Details
Continuous playback: up to 8 hours
Recharge Time
2 hours
Type: Headphones
Colour: Blue
Brand: JBL
