Bring your sound everywhere. With bass you can feel, up to 32 total hours of battery life, and a secure, comfortable stick-open design, the splash and dust resistant JBL Wave Flex are designed for daily entertainment. Whether you're roaming city streets or relaxing on the beach, your hands-free stereo calls will always be crystal clear, while Smart Ambient technology keeps you aware of your surroundings and when you need an extra boost, you can speed charge two additional hours of power in just 10 minutes.
With 8 hours of battery life in the earbuds and 24 in the case, the JBL Wave Flex provide all day audio and when you need more power, you can speed charge an extra two hours in just 10 minutes.
When you're making hands-free stereo calls on the go, VoiceAware lets you balance how much of your own voice you can hear while talking with others. Get the most from your mixes with high-quality audio from secure, reliable earbuds with 12mm drivers featuring JBL deep bass sound.
From the beach to the bike trail, the IP54-certified earbuds and IPX2 charging case are water and dust resistant for all-day experiences.
JBL Deep Bass Sound
Get the most from your mixes with high-quality audio from secure, reliable earbuds with 12mm drivers featuring JBL Deep Bass Sound. -
Comfortable fit
The ergonomic, stick-open design of the JBL Wave Flex fits so comfortably you may forget you're wearing them. The stick-open design allows you to enjoy all the sound without blocking your ear-canal. -
Long battery life with speed charging
With long battery life in the earbuds and more in the case, the JBL Wave Flex provide all-day audio. And when you need more power, you can speed charge an extra two hours in just 10 minutes.
- JBL Wave Flex - true wireless earphones with mic
- Product Type
- True wireless earphones - Bluetooth
- Recommended Use
- Portable electronics
- Black
- Headphones Form Factor
- In-ear
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.2
- Sound Output Mode
- Stereo
- Sound Effects
- Deep Bass
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 105 dB
- Impedance
- 16 Ohm
- Product Type
- True wireless earphones - Bluetooth - wireless
- Dimensions & Weight Details
- Earbud: 1.857 cm x 3.348 cm x 1.846 cm / 3.8 g , Charging case: 4.937 cm x 5.484 cm x 2.585 cm / 35.1 g
- Black
- Recommended Use
- Protection
- Dust-resistant, water-resistant
Audio Output
- In-ear
- Connectivity Technology
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 5.2
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- Sound Effects
- Deep Bass
- 20 - 20000 Hz
- Sensitivity
- 105 dB
- Impedance
- 16 Ohm
- Max Sound Pressure
- 95 dB
- Diaphragm
- 12 mm
Microphone
- Form Factor
- Built-in
- Sensitivity
- -38 dBV/Pascal
- Included Accessories
- Charging case (500 mAh), USB-C charging cable
- IP54
- Battery
- Headphone battery rechargeable - Lithium Ion
- Capacity
- 40 mAh
- Run Time Details
- Continuous playback: up to 8 hours , Continuous playback (with included charging case): up to 32 hours , Continuous talk: up to 4.5 hours
- Recharge Time
- 2 hours
